Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Introducción
This is instructions on how to open up the phone to get to the insides.
Partes
No se especificaron partes.
  1. Press and slide open the battery cover. Press and slide open the battery cover.
    • Press and slide open the battery cover.
  2. Caution: Turn cell phone off before removing battery!
    • Caution: Turn cell phone off before removing battery!
    • Press battery to the right.
    • Then lift up battery pack to remove.
  3. Phone with battery removed
    • Phone with battery removed
  4. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
    • Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
  6. Lift the rubber cap at the top right to reveal the sixth screw.
    • Lift the rubber cap at the top right to reveal the sixth screw.
    • Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
    • Remove the six screws using the T5 Torx screwdriver.
  7. Remove the SIM card so housing can be separated. Remove the SIM card so housing can be separated.
    • Remove the SIM card so housing can be separated.
  8. Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert. Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
    • Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
  9. Remove the small plastic insert at the bottom of the phone. Remove the small plastic insert at the bottom of the phone.
    • Remove the small plastic insert at the bottom of the phone.
  10. Continue with plastic pry tool all the way around the phone to remove the back housing. Continue with plastic pry tool all the way around the phone to remove the back housing.
    • Continue with plastic pry tool all the way around the phone to remove the back housing.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 15-49, Garner Spring 2010 Miembro de Cal Poly, Team 15-49, Garner Spring 2010
CPSU-GARNER-S10S15G49
5 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 3,630
