Saltar al contenido principal
Palm Centro Back Housing Replacement
Qué necesitas
  1. Palm Centro Back Housing Replacement, Disassembling Palm Centro Battery: paso 1, imagen 1 de 2 Palm Centro Back Housing Replacement, Disassembling Palm Centro Battery: paso 1, imagen 2 de 2
    • Press and slide open the battery cover.
  2. Palm Centro Back Housing Replacement: paso 2, imagen 1 de 1
    • Caution: Turn cell phone off before removing battery!
    • Press battery to the right.
    • Then lift up battery pack to remove.
  3. Palm Centro Back Housing Replacement: paso 3, imagen 1 de 1
    • Phone with battery removed
  4. Palm Centro Back Housing Replacement, Back Housing: paso 4, imagen 1 de 1
    • Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
  5. Palm Centro Back Housing Replacement: paso 5, imagen 1 de 1
    • Lift the rubber cap at the top right to reveal the sixth screw.
    • Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
    • Remove the six screws using the T5 Torx screwdriver.
  6. Palm Centro Back Housing Replacement: paso 6, imagen 1 de 2 Palm Centro Back Housing Replacement: paso 6, imagen 2 de 2
    • Remove the SIM card so housing can be separated.
  7. Palm Centro Back Housing Replacement: paso 7, imagen 1 de 2 Palm Centro Back Housing Replacement: paso 7, imagen 2 de 2
    • Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
  8. Palm Centro Back Housing Replacement: paso 8, imagen 1 de 2 Palm Centro Back Housing Replacement: paso 8, imagen 2 de 2
    • Remove the small plastic insert at the bottom of the phone.
  9. Palm Centro Back Housing Replacement: paso 9, imagen 1 de 2 Palm Centro Back Housing Replacement: paso 9, imagen 2 de 2
    • Continue with plastic pry tool all the way around the phone to remove the back housing.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 15-49, Garner Spring 2010 Miembro de Cal Poly, Team 15-49, Garner Spring 2010
CPSU-GARNER-S10S15G49
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 3,774
