Saltar al contenido principal
Packard Bell ms-Hera c Disassembly
Qué necesitas
  1. Packard Bell ms-Hera c Disassembly, Unscrew the lid: paso 1, imagen 1 de 3 Packard Bell ms-Hera c Disassembly, Unscrew the lid: paso 1, imagen 2 de 3 Packard Bell ms-Hera c Disassembly, Unscrew the lid: paso 1, imagen 3 de 3
    • Remove the battery.
    • Unscrew the red marked screws with a Phillips screwdriver.
    • Remove the DVD reader.
  2. Packard Bell ms-Hera c Disassembly, Disconnect the keyboard: paso 2, imagen 1 de 3 Packard Bell ms-Hera c Disassembly, Disconnect the keyboard: paso 2, imagen 2 de 3 Packard Bell ms-Hera c Disassembly, Disconnect the keyboard: paso 2, imagen 3 de 3
    • Pry in the red marked spots to release the keyboard
    • Unplug the keyboard connector.
  3. Packard Bell ms-Hera c Disassembly, Unplug the cables: paso 3, imagen 1 de 3 Packard Bell ms-Hera c Disassembly, Unplug the cables: paso 3, imagen 2 de 3 Packard Bell ms-Hera c Disassembly, Unplug the cables: paso 3, imagen 3 de 3
    • Unplug the 3 connectors on the motherboard
    • Remove the 2 screws holding the display in place
    • Use a thin tool to pry up the back cover of the laptop on the side
  4. Packard Bell ms-Hera c Disassembly, Unscrew the motherboard: paso 4, imagen 1 de 3 Packard Bell ms-Hera c Disassembly, Unscrew the motherboard: paso 4, imagen 2 de 3 Packard Bell ms-Hera c Disassembly, Unscrew the motherboard: paso 4, imagen 3 de 3
    • Remove the back cover.
    • Remove the HDD.
    • Remove the screws that hold the motherboard.
  5. Packard Bell ms-Hera c Disassembly, Remove the display: paso 5, imagen 1 de 3 Packard Bell ms-Hera c Disassembly, Remove the display: paso 5, imagen 2 de 3 Packard Bell ms-Hera c Disassembly, Remove the display: paso 5, imagen 3 de 3
    • Remove the marked screws and connectors.
    • Disconnect the display connector.
    • Remove the display.
  6. Packard Bell ms-Hera c Disassembly, Remove the heatsink: paso 6, imagen 1 de 3 Packard Bell ms-Hera c Disassembly, Remove the heatsink: paso 6, imagen 2 de 3 Packard Bell ms-Hera c Disassembly, Remove the heatsink: paso 6, imagen 3 de 3
    • Remove the cooling fan.
    • Remove the heatsink.
    • Remove the screws on the connector.
  7. Packard Bell ms-Hera c Disassembly, Remove the motherboard: paso 7, imagen 1 de 2 Packard Bell ms-Hera c Disassembly, Remove the motherboard: paso 7, imagen 2 de 2
    • Remove the screws to remove the motherboard.
Conclusión
Una persona más ha completado esta guía.
Un agradecimiento especial a estos traductores:
it en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Smilzo
Miembro Desde 11/09/13
11,060 Reputación
39 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 876
