Introducción
This guide will show you how to remove the drive cage from a Packard Bell 4X4 desktop so you can replace the optical drive, hard drive or floppy drive.
Partes
No se requieren partes.
  1. Remove the 3 Philips head screws from the back of the computer using your Philips screwdriver.
    • Remove the 3 Philips head screws from the back of the computer using your Philips screwdriver.
  2. Using both hands on each side of the case, slide the top cover toward you. Lift it up off the computer.
    • Using both hands on each side of the case, slide the top cover toward you. Lift it up off the computer.
  3. The top cover is removed.
    • The top cover is removed.
  4. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  5. Remove the two Philips head screws with your Philips screwdriver. You may have to lubricate these screws as they can be very difficult to remove.
    • Remove the two Philips head screws with your Philips screwdriver. You may have to lubricate these screws as they can be very difficult to remove.
  6. Remove the 1 Philips head screw from the left hand side of the case if there is one. Again, you may need to lubricate this screw.
    • Remove the 1 Philips head screw from the left hand side of the case if there is one. Again, you may need to lubricate this screw.
  7. Once the screws are removed, disconnect all cables from the optical drive, hard drive and floppy drive.
    • Once the screws are removed, disconnect all cables from the optical drive, hard drive and floppy drive.
  8. Slide the drive cage back. An easy way to do this is the push on the optical drive from the front.
    • Slide the drive cage back. An easy way to do this is the push on the optical drive from the front.
  9. Lift the drive cage up and out of the computer.
    • Lift the drive cage up and out of the computer.
Conclusión
2 personas más completaron esta guía.
Brandon S
Miembro Desde 04/09/10
492 Reputación
3 Guías creadas
Equipo
Packard Bell Planet Miembro de Packard Bell Planet
Community
1 Miembro
6 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 9
Todo El Tiempo: 1,300
