Saltar al contenido principal
Pacific Image Electronics CS3600 Button Spring Replacement
Qué necesitas
  1. Pacific Image Electronics CS3600 Button Spring Replacement, Button Spring: paso 1, imagen 1 de 1
    • Begin opening the device by unscrewing the 5 following 9mm x 7mm screws with a J1 screwdriver.
  2. Pacific Image Electronics CS3600 Button Spring Replacement: paso 2, imagen 1 de 1
    • Once the screws have been removed, with light force open the scanner by pulling it apart at the seam.
  3. Pacific Image Electronics CS3600 Button Spring Replacement: paso 3, imagen 1 de 1
    • With a JIS J0 screwdriver remove the 1 screw that is 7mm x 6mm.
  4. Pacific Image Electronics CS3600 Button Spring Replacement: paso 4, imagen 1 de 1
    • Lift and move the plate with the connected wires out of the way.
  5. Pacific Image Electronics CS3600 Button Spring Replacement: paso 5, imagen 1 de 1
    • Remove the spring and replace it with a new one.
Conclusión
Amber Berry
Miembro Desde 03/21/17
101 Reputación
1 Guía escrita
Equipo
Texas Tech, Team S46-G2, Bennett Spring 2017 Miembro de Texas Tech, Team S46-G2, Bennett Spring 2017
TTU-BENNETT-S17S46G2
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 167
