Saltar al contenido principal
PSP Go Back Cover Replacement
Qué necesitas
  1. PSP Go Back Cover Replacement, Back Cover: paso 1, imagen 1 de 2 PSP Go Back Cover Replacement, Back Cover: paso 1, imagen 2 de 2
    • Unscrew the four Phillips screws on the back of the PSP Go.
    • Rotate the PSP so you can see the top of the device.
    • Unscrew the two Phillips screws next to the volume buttons.
  2. PSP Go Back Cover Replacement: paso 2, imagen 1 de 2 PSP Go Back Cover Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
    • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
    • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 19
Ultimos 30 días: 59
Todo El Tiempo: 18,586
