Introducción
PSP E1000 / E1004
not read UMD games and you haven't indication for insertion games. The problem probably is in UMD switch.
You can see the video:
Resumen del Video
  1. If you haven't indication for inserted disk the problem probably is in UMD switch. If you haven't indication for inserted disk the problem probably is in UMD switch. If you haven't indication for inserted disk the problem probably is in UMD switch.
    • If you haven't indication for inserted disk the problem probably is in UMD switch.
  2. Unhook the door metal plate and disassemble UMD door. Unhook the door metal plate and disassemble UMD door. Unhook the door metal plate and disassemble UMD door.
    • Unhook the door metal plate and disassemble UMD door.
  3. With a screwdriver I short the UMD switch to test the laser. With a screwdriver I short the UMD switch to test the laser.
    • With a screwdriver I short the UMD switch to test the laser.
  4. Now let's disassemble it. Now let's disassemble it. Now let's disassemble it.
    • Now let's disassemble it.
  5. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  6. Disconnect and remove the display. Disconnect and remove the display. Disconnect and remove the display.
    • Disconnect and remove the display.
  7. I must disconnect 7x cables and unscrew a screw. I must disconnect 7x cables and unscrew a screw.
    • I must disconnect 7x cables and unscrew a screw.
  8. Now I disconnect the battery connector and here is the mainboard. Now I disconnect the battery connector and here is the mainboard. Now I disconnect the battery connector and here is the mainboard.
    • Now I disconnect the battery connector and here is the mainboard.
  9. I used soldering station to remove the old one and put the new one (UMD switch). I used soldering station to remove the old one and put the new one (UMD switch).
    • I used soldering station to remove the old one and put the new one (UMD switch).
  10. Let's assemble and test it. Let's assemble and test it. Let's assemble and test it.
    • Let's assemble and test it.
Conclusión
3 personas más completaron esta guía.
ZFix
Miembro Desde 09/12/13
162,554 Reputación
304 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
280 Miembros
784 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 11
Últimos 30 Días: 63
Todo El Tiempo: 5,430
