Saltar al contenido principal
PSP 300xc Speakers Replacement
Qué necesitas
  1. PSP 300xc Speakers Replacement, Battery: paso 1, imagen 1 de 2 PSP 300xc Speakers Replacement, Battery: paso 1, imagen 2 de 2
    • Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
    • Lift the battery out of the PSP.
  2. PSP 300xc Speakers Replacement, Front Case: paso 2, imagen 1 de 1
    • Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
  3. PSP 300xc Speakers Replacement: paso 3, imagen 1 de 2 PSP 300xc Speakers Replacement: paso 3, imagen 2 de 2
    • Remove four Phillips screws from the back of the PSP.
  4. PSP 300xc Speakers Replacement: paso 4, imagen 1 de 1
    • Remove two Phillips screws from the top of the PSP.
  5. PSP 300xc Speakers Replacement: paso 5, imagen 1 de 1
    • Remove a single screw from the bottom edge of the PSP.
  6. PSP 300xc Speakers Replacement: paso 6, imagen 1 de 2 PSP 300xc Speakers Replacement: paso 6, imagen 2 de 2
    • Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
  7. PSP 300xc Speakers Replacement, LCD: paso 7, imagen 1 de 1
    • Remove a single Phillips screw securing the home bar to the PSP 300xc.
  8. PSP 300xc Speakers Replacement: paso 8, imagen 1 de 2 PSP 300xc Speakers Replacement: paso 8, imagen 2 de 2
    • Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly.
    • Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
  9. PSP 300xc Speakers Replacement: paso 9, imagen 1 de 1
    • Insert a spudger under the LCD, beside the black plastic tab.
    • Push the LCD to the left and pry up to release the left edge of the LCD from under the plastic tab.
  10. PSP 300xc Speakers Replacement: paso 10, imagen 1 de 1
    • Push the LCD to the right and pry up to release the right edge of the LCD from under the plastic tab.
  11. PSP 300xc Speakers Replacement: paso 11, imagen 1 de 3 PSP 300xc Speakers Replacement: paso 11, imagen 2 de 3 PSP 300xc Speakers Replacement: paso 11, imagen 3 de 3
    • Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables.
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors:
    • Home bar cable
    • Microphone cable
    • LCD display data cable
    • Touchscreen cable
    • Be sure you are prying up on the retaining flap, not the socket itself
    • After flipping up the locking tabs on all four connectors, use your fingers or a spudger to gently pull the cables straight out of the connectors.
  12. PSP 300xc Speakers Replacement: paso 12, imagen 1 de 1
    • Remove the LCD from the PSP 300xc.
  13. PSP 300xc Speakers Replacement, Home Bar: paso 13, imagen 1 de 3 PSP 300xc Speakers Replacement, Home Bar: paso 13, imagen 2 de 3 PSP 300xc Speakers Replacement, Home Bar: paso 13, imagen 3 de 3
    • Lift the home bar up as high as it will go, but not so high that the wires disconnect.
    • Try to bend the small tab under the silver rim as little as possible it the following steps. The more you bend, the more likely it will snap.
    • Twist the home bar counter clockwise while carefully lifting it further. The left edge has to lift over the black plastic frame to allow it to rotate.
    • The home bar should now lift out of the PSP 300xc.
  14. PSP 300xc Speakers Replacement, Speakers: paso 14, imagen 1 de 1
    • Using the flat end of a spudger, peel the left trigger contact pad up from the case.
  15. PSP 300xc Speakers Replacement: paso 15, imagen 1 de 2 PSP 300xc Speakers Replacement: paso 15, imagen 2 de 2
    • Using a fingernail or spudger, flip up the retaining bracket on the d-pad and 'L' trigger ribbon cable.
    • Lift the black plastic bracket along with the d-pad contact pad, disconnecting the ribbon cable as you lift.
  16. PSP 300xc Speakers Replacement: paso 16, imagen 1 de 1
    • Pop the left speaker out from the bottom of the black plastic bracket.
    • Set the left speaker aside.
  17. PSP 300xc Speakers Replacement: paso 17, imagen 1 de 1
    • Push the black tab holding the right speaker down to the left.
    • The speaker will pop out of place after pushing the tab.
    • Remove the speaker.
Conclusión
Matthew Newsom
Miembro Desde 01/05/10
39,500 Reputación
67 Guías creadas
Un comentario
How do i apply the right speaker after deconstruction?
angelsthegoat - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 20
Todo El Tiempo: 1,716
