Saltar al contenido principal
PSP 300x Front Casing Replacement
Qué necesitas
  1. PSP 300x Front Casing Replacement, Battery: paso 1, imagen 1 de 3 PSP 300x Front Casing Replacement, Battery: paso 1, imagen 2 de 3 PSP 300x Front Casing Replacement, Battery: paso 1, imagen 3 de 3
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
  2. PSP 300x Front Casing Replacement, Front Casing: paso 2, imagen 1 de 1
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
  3. PSP 300x Front Casing Replacement: paso 3, imagen 1 de 2 PSP 300x Front Casing Replacement: paso 3, imagen 2 de 2
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
  4. PSP 300x Front Casing Replacement: paso 4, imagen 1 de 1
    • Next, unscrew the two screws located at the top of the PSP.
  5. PSP 300x Front Casing Replacement: paso 5, imagen 1 de 1
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
  6. PSP 300x Front Casing Replacement: paso 6, imagen 1 de 2 PSP 300x Front Casing Replacement: paso 6, imagen 2 de 2
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
Conclusión
28 personas más completaron esta guía.
kbrunner
Miembro Desde 11/05/09
81 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 19-2, Maness Fall 2009 Miembro de Cal Poly, Team 19-2, Maness Fall 2009
CPSU-MANESS-F09S19G2
3 Miembros
12 Guías creadas
Un comentario
This is only the faceplate, not a casing replacement, come on
Dick - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 97
Ultimos 30 días: 344
Todo El Tiempo: 19,598
