Saltar al contenido principal
PSP 1000 Front Casing Replacement
Qué necesitas
  1. PSP 1000 Front Casing Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the PSP over so its back is facing you.
  2. PSP 1000 Front Casing Replacement: paso 2, imagen 1 de 2 PSP 1000 Front Casing Replacement: paso 2, imagen 2 de 2
    • Locate the battery casing button on the rear-left side of the PSP.
    • Press down the button and remove the battery cover.
  3. PSP 1000 Front Casing Replacement: paso 3, imagen 1 de 2 PSP 1000 Front Casing Replacement: paso 3, imagen 2 de 2
    • Using your finger, remove the battery upwards from the system as shown.
  4. PSP 1000 Front Casing Replacement, Front Casing: paso 4, imagen 1 de 2 PSP 1000 Front Casing Replacement, Front Casing: paso 4, imagen 2 de 2
    • Remove the four screws shown with a Phillips #00 screwdriver.
    • You will have to peel back the guarantee sticker to access the screw on the lower left.
  5. PSP 1000 Front Casing Replacement: paso 5, imagen 1 de 1
    • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
    • Remove screws from back righthand side within the holes.
  6. PSP 1000 Front Casing Replacement: paso 6, imagen 1 de 2 PSP 1000 Front Casing Replacement: paso 6, imagen 2 de 2
    • Gently separate the outer plastic casing from the rest of the system as shown.
Conclusión
32 personas más completaron esta guía.
Henry Lee
Miembro Desde 01/14/10
752 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 5-6, Forte Winter 2010 Miembro de Cal Poly, Team 5-6, Forte Winter 2010
CPSU-FORTE-W10S5G6
5 Miembros
19 Guías creadas
3 comentarios
Thank you! Awesome help!
Jay Vee - Contestar
My psp is updating then psp is fallen down and battery comeout so please help me please thank you
Bye
National Nazeer - Contestar
i also made a video on this for anyone who needs to do it that way.
https://www.youtube.com/watch?v=EIAaJyIx...
DAS Repair - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 72
Ultimos 30 días: 323
Todo El Tiempo: 36,813
