Introducción
There comes a time in every controllers lifespan where the battery just seems to stop working, but don't worry, with this guide you can replace the battery and rejuvenate your controller's life span.
Remove the two 10 mm Phillips #1 screws that secure each of the handle grips.
Pull off the handle grips.
Use blunt tweezers to pull the white battery motherboard connector directly out of its port.
Gently peel the battery off of the motherboard.
Una persona más ha completado esta guía.
