Saltar al contenido principal
Introducción
To complete this repair, the user must possess skills in soldering, and proper tools needed to perform the repair.
  1. Remove the 5 screws on the back of the controller.
    • Remove the 5 screws on the back of the controller.
    • The back housing of the controller can now be removed.
  2. Remove battery by unlatching the battery cables from battery connector clip.
    • Remove battery by unlatching the battery cables from battery connector clip.
  3. Remove the two screws holding the motherboard to the front controller housing.
    • Remove the two screws holding the motherboard to the front controller housing.
    • Next, remove the motherboard assembly from the controller housing. This is done by pressing in the clips on each side of the handle.
    • Freeing the motherboard from the housing will provide better access to the charging port.
  4. Prepare your station for the de-soldering of the charging port.
    • Prepare your station for the de-soldering of the charging port.
  5. To remove the defective charging port, you will need to de-solder the 9 pins holding the port to the motherboard. First, used the desoldering pump to remove the solder from all 9 pins. Then, use the desoldering wick to remove any excess solder left on the motherboard.
    • To remove the defective charging port, you will need to de-solder the 9 pins holding the port to the motherboard.
    • First, used the desoldering pump to remove the solder from all 9 pins.
    • Then, use the desoldering wick to remove any excess solder left on the motherboard.
  6. After the charging port is removed, place the new charging port into position.
    • After the charging port is removed, place the new charging port into position.
    • Hold the new port in place by using a clip to keep it from moving.
  7. Tin the soldering iron before soldering the connections. This is done by applying a small amount of solder to the tip of the hot iron. Solder the 9 pin connections that connect the charging port to the motherboard.
    • Tin the soldering iron before soldering the connections. This is done by applying a small amount of solder to the tip of the hot iron.
    • Solder the 9 pin connections that connect the charging port to the motherboard.
Conclusión
To reassemble your device, follow instructions 1-3 in reverse order.
8 personas más completaron esta guía.
Attak
Miembro Desde 04/12/17
375 Reputación
1 Guía escrita
Un Comentario
Shall DualShock3 require other than GND and VBUS for charging only
and does DS3 follow the standards of USB-miniB (eg: Data wires flipping).
Sony does have some fame to sacrifice standards over extra capability delivery.
JanLS - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 54
Ultimos 30 días: 167
Todo El Tiempo: 8,234
