Introducción
Note::: taking apart your device may void the warranty on the device, please proceed with caution and consider having it sent in first if possible to be worked on by the company. A screwdriver would be required for this action. So far we have been using the J00 head in the ifixit kit. Be careful when completing this action as you should have the entire back cover ready to be pulled off before attempting to do so. Having just the bottom or the top pulled up is not enough to get a safe removal, as there is some ribbons that may be damaged if pulled off wrong.
Qué necesitas
All 6.35mm screws were removed using a J00 bit from the iFixit pro toolkit.
There are four screws on the back of the device, remove them as shown.
