Qué necesitas
Open the memory protection
Remove gently the rear cover
When re-assembly take care to the thin tabs
This connector is directly to the board
This Flex connector need to be unplug
The 321 battery is there
You can add some thermal glue to fix the battery
I did it with a small piece of scotch
To re-assembly your device follow the step backward
Un agradecimiento especial a estos traductores:
100%
¡ Bertrand PIGEARD nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
