Saltar al contenido principal
PE254 Nose Pad Replacement
Qué necesitas
  1. PE254 Nose Pad Replacement, Nose Pad: paso 1, imagen 1 de 1
    • Assess the eyewear for nose pad damage or cracks.
  2. PE254 Nose Pad Replacement: paso 2, imagen 1 de 1
    • Place a 3-inch strip of tape on the lenses to protect them from being scratched.
  3. PE254 Nose Pad Replacement: paso 3, imagen 1 de 1
    • Unscrew the nose pad screw using a Phillips-head screw driver. Turn the screw counter-clockwise until the screw can be removed
  4. PE254 Nose Pad Replacement: paso 4, imagen 1 de 3 PE254 Nose Pad Replacement: paso 4, imagen 2 de 3 PE254 Nose Pad Replacement: paso 4, imagen 3 de 3
    • Remove the old nose pad and replace with a new one.
  5. PE254 Nose Pad Replacement: paso 5, imagen 1 de 1
    • Place the screw back inside of the nose pad and turn clockwise until the screw is tight. Do not overtighten.
  6. PE254 Nose Pad Replacement: paso 6, imagen 1 de 1
    • Repeat steps on the other side
    • Be careful when readjusting the pads.
Linea de Meta
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 37
Todo El Tiempo: 1,746
