Introducción
If you need to replace a thumbstick of your PDP Rematch Advanced, take out the back shell with this guide. Both thumbsticks are attached to the motherboard. The thumbstick can be removed by taking out the back shell and twisting the thumbstick off of the motherboard.
Qué necesitas
Orient the controller so the back side is facing you.
Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
Una persona más ha completado esta guía.
