Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
PDP Rematch Advanced Shoulder Buttons Replacement
Qué necesitas
  1. PDP Rematch Advanced Shoulder Buttons Replacement, Front Housing Shell: paso 1, imagen 1 de 3 PDP Rematch Advanced Shoulder Buttons Replacement, Front Housing Shell: paso 1, imagen 2 de 3 PDP Rematch Advanced Shoulder Buttons Replacement, Front Housing Shell: paso 1, imagen 3 de 3
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
  2. PDP Rematch Advanced Shoulder Buttons Replacement: paso 2, imagen 1 de 3 PDP Rematch Advanced Shoulder Buttons Replacement: paso 2, imagen 2 de 3 PDP Rematch Advanced Shoulder Buttons Replacement: paso 2, imagen 3 de 3
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
  3. PDP Rematch Advanced Shoulder Buttons Replacement: paso 3, imagen 1 de 3 PDP Rematch Advanced Shoulder Buttons Replacement: paso 3, imagen 2 de 3 PDP Rematch Advanced Shoulder Buttons Replacement: paso 3, imagen 3 de 3
    • Peel the rubber piece off the back of the face buttons.
  4. PDP Rematch Advanced Shoulder Buttons Replacement: paso 4, imagen 1 de 3 PDP Rematch Advanced Shoulder Buttons Replacement: paso 4, imagen 2 de 3 PDP Rematch Advanced Shoulder Buttons Replacement: paso 4, imagen 3 de 3
    • Push all the face buttons out from the front of the shell.
  5. PDP Rematch Advanced Shoulder Buttons Replacement: paso 5, imagen 1 de 3 PDP Rematch Advanced Shoulder Buttons Replacement: paso 5, imagen 2 de 3 PDP Rematch Advanced Shoulder Buttons Replacement: paso 5, imagen 3 de 3
    • Put two fingers behind the bumpers and push upwards to remove them.
  6. PDP Rematch Advanced Shoulder Buttons Replacement, Shoulder Buttons: paso 6, imagen 1 de 3 PDP Rematch Advanced Shoulder Buttons Replacement, Shoulder Buttons: paso 6, imagen 2 de 3 PDP Rematch Advanced Shoulder Buttons Replacement, Shoulder Buttons: paso 6, imagen 3 de 3
    • Push down on the trigger's long paddle.
    • Carefully twist the bumper out to remove it from the bumper frame.
Conclusión
Una persona más ha completado esta guía.
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 65
Todo El Tiempo: 651
