Saltar al contenido principal
PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement
Qué necesitas
  1. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement, Joysticks: paso 1, imagen 1 de 1
    • Remove the two 11 mm screws from the back of the controller using a Phillips #0 screwdriver.
    • Remove the five 8 mm screws from the back of the controller using a Phillips #0 screwdriver.
  2. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: paso 2, imagen 1 de 1
    • Remove the back cover from the controller and set it aside.
  3. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: paso 3, imagen 1 de 1
    • Remove the circuit board from the front casing.
    • Be cautious of disconnecting the vibration motors which are attached by thin wires.
  4. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: paso 4, imagen 1 de 3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: paso 4, imagen 2 de 3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: paso 4, imagen 3 de 3
    • Wiggle and pull the joystick until it comes off of the circuit board.
  5. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: paso 5, imagen 1 de 2 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: paso 5, imagen 2 de 2
    • Place the new joystick into position and press until the joystick makes a click.
  6. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: paso 6, imagen 1 de 1
    • Place the circuit board and vibration motors back into the front casing.
  7. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: paso 7, imagen 1 de 3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: paso 7, imagen 2 de 3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: paso 7, imagen 3 de 3
    • Place the back cover into position.
    • Reinsert the two 11 mm screws into the back of the controller using a Phillips #0 screwdriver.
    • Reinsert the five 8 mm screws into the back of the controller using a Phillips #0 screwdriver.
Linea de Meta
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 43
Ultimos 30 días: 103
Todo El Tiempo: 2,747
