Saltar al contenido principal
PDP Afterglow Wired Xbox 360 Controller Button Replacement
Qué necesitas
  1. PDP Afterglow Wired Xbox 360 Controller Button Replacement, Case: paso 1, imagen 1 de 2 PDP Afterglow Wired Xbox 360 Controller Button Replacement, Case: paso 1, imagen 2 de 2
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller Button Replacement: paso 2, imagen 1 de 1
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller Button Replacement: paso 3, imagen 1 de 1
    • Remove the top cover from the bottom and place next to each other.
  4. PDP Afterglow Wired Xbox 360 Controller Button Replacement, Button: paso 4, imagen 1 de 1
    • Remove the rubber button covers from the A, B, X, and Y buttons.
  5. PDP Afterglow Wired Xbox 360 Controller Button Replacement: paso 5, imagen 1 de 2 PDP Afterglow Wired Xbox 360 Controller Button Replacement: paso 5, imagen 2 de 2
    • Push up on the buttons from the front and pull them out from the back.
Conclusión
3 personas más completaron esta guía.
Joi Officer
Miembro Desde 09/17/15
283 Reputación
2 Guías creadas
Equipo
IUPUI, Team 3-1, Harley Fall 2015 Miembro de IUPUI, Team 3-1, Harley Fall 2015
IUPUI-HARLEY-F15S3G1
4 Miembros
5 Guías creadas
3 comentarios
What about removing the Dpad? i really need help.
Elijah Douglas - Contestar
I’m sorry but, I have to say that the reassembly process is harder than simply ‘follow the instructions in reverse’; if you try and place the half with the buttons, the buttons fall out or end up misaligned ; and if you use the other half, the rubber covers and the tumblers will fall out.
Again, this guild comes off a little too simple, there’s more to it.
Christopher Mali-Martinez - Contestar
the circuit board comes off the other half. You can stack them very easily. You're simply incorrect.
Tyler Anderson -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 25
Todo El Tiempo: 4,940
