Introducción
First you are going to start with your already broken wireless dongle USB wire, then we are going to cut the other end exposing the wire on that side.
Next we will link the wires together and then wrap it in heat shrink and mold them together. WARNING: Some wiring and soldering skills required.
Qué necesitas
First, remove the heat shrink from the new USB.
Then remove the signal shield protection from the new USB.
Next, cut the 4 wire ends that are now protruding from the end of the USB.
This guide does not require reassembly, as the guide itself is re-attaching the USB.
