Introducción
This guide describes the steps needed to install acro brake handles on your wing.
Qué necesitas
Open the brake handle knot on one of your brakes as shown in the pictures.
By default there should be a mark on your brake line just above the knot!
Finally remove the line from the brake handle
If you would like to have free brakes - remove the break line from the pulley
Make a little loop on the brake line (the open end beeing on the right hand side in the picture)
Put the brake line through the loop on the acro brake handle
put the open end of the line through the loop on the brake line (from behind)
now route the open end of the brake line behind the brake line that goes up to the glider.
and back through the loop
Arrange the brake line knot that the mark on the brake line again is just over the brake line knot - and pull the knot tight
If you want you can store the rest of the line like this (or any other method comfortable)
Prepare bungees as shown in the picture with a loop on one side and a knot on the other side.
The loop should just be big enough to fit over your riser and not fall off.
Put the loop around the bottom of the riser as shown in the 2nd picture.
Do not pull the open end of the bungee through the loop at the bottom of the riser - the open end should come out to the 'outside' of the riser.
There is a loop on the bottom of the Ozone Acro Brake Handle. Prepare the loop as shown in the first and second picture
Put the bungee through the prepared loop
Arrange it and pull tight
Voila! You installed acro handles on your glider.
Do the same thing on the other side of the glider!
You do any modification on your glider at your own risk!
Una persona más ha completado esta guía.
