Saltar al contenido principal
Osterizer Blender 14 Speed All Metal Drive Disassembly
Qué necesitas
  1. Osterizer Blender 14 Speed All Metal Drive Disassembly, Osterizer Blender 14 Speed All Metal Drive Disassembly: paso 1, imagen 1 de 2 Osterizer Blender 14 Speed All Metal Drive Disassembly, Osterizer Blender 14 Speed All Metal Drive Disassembly: paso 1, imagen 2 de 2
    • Take the blender and place the top, cup, and blades aside
    • Blades of the blender are sharp, so when setting aside do not cut yourself
  2. Osterizer Blender 14 Speed All Metal Drive Disassembly: paso 2, imagen 1 de 2 Osterizer Blender 14 Speed All Metal Drive Disassembly: paso 2, imagen 2 de 2
    • Flip over the base containing the motor of the blender
    • Use the Phillips Head Screwdriver to remove the 4 screws as pictured
  3. Osterizer Blender 14 Speed All Metal Drive Disassembly: paso 3, imagen 1 de 1
    • Remove the bottom panel
  4. Osterizer Blender 14 Speed All Metal Drive Disassembly: paso 4, imagen 1 de 1
    • Use an 11mm screwdriver to remove the screw from the fan blade
    • Remove the fan blade
  5. Osterizer Blender 14 Speed All Metal Drive Disassembly: paso 5, imagen 1 de 1
    • Locate the washer beneath the fan and remove it from the motor
    • To remove the washer, twist it in a counterclockwise motion
  6. Osterizer Blender 14 Speed All Metal Drive Disassembly: paso 6, imagen 1 de 2 Osterizer Blender 14 Speed All Metal Drive Disassembly: paso 6, imagen 2 de 2
    • Use a 6.5mm wrench and extender to remove the 2 screws holding the top of the motor in place
  7. Osterizer Blender 14 Speed All Metal Drive Disassembly: paso 7, imagen 1 de 3 Osterizer Blender 14 Speed All Metal Drive Disassembly: paso 7, imagen 2 de 3 Osterizer Blender 14 Speed All Metal Drive Disassembly: paso 7, imagen 3 de 3
    • Take out the motor and copper wires from the blender
  8. Osterizer Blender 14 Speed All Metal Drive Disassembly: paso 8, imagen 1 de 3 Osterizer Blender 14 Speed All Metal Drive Disassembly: paso 8, imagen 2 de 3 Osterizer Blender 14 Speed All Metal Drive Disassembly: paso 8, imagen 3 de 3
    • Disconnect the 2 white wires that connect the motor to the motherboard
    • These 2 wires have silver tips
  9. Osterizer Blender 14 Speed All Metal Drive Disassembly: paso 9, imagen 1 de 3 Osterizer Blender 14 Speed All Metal Drive Disassembly: paso 9, imagen 2 de 3 Osterizer Blender 14 Speed All Metal Drive Disassembly: paso 9, imagen 3 de 3
    • Remove the 4 bolts connecting the motor to the blender wall using a socket wrench
  10. Osterizer Blender 14 Speed All Metal Drive Disassembly: paso 10, imagen 1 de 1
    • Flip the blender back over to the original position and remove the metal disk located at the top of the blender using pliers
  11. Osterizer Blender 14 Speed All Metal Drive Disassembly: paso 11, imagen 1 de 2 Osterizer Blender 14 Speed All Metal Drive Disassembly: paso 11, imagen 2 de 2
    • Fully remove the motor from the blender
Conclusión
Kaia Williams
Miembro Desde 11/22/22
193 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 111
