Saltar al contenido principal
Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement
Qué necesitas
  1. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement, Top Panel Removal: paso 1, imagen 1 de 1
    • Remove the bread pan.
  2. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: paso 2, imagen 1 de 3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: paso 2, imagen 2 de 3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: paso 2, imagen 3 de 3
    • Remove the eight 22mm Phillips #1 screws from the grey lining.
    • Remove the grey liner.
  3. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: paso 3, imagen 1 de 2 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: paso 3, imagen 2 de 2
    • Remove the two 11mm Phillips #1 screws from the back of the device.
  4. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: paso 4, imagen 1 de 2 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: paso 4, imagen 2 de 2
    • Pop off the top case using a spudger.
    • Keep the spudger away from the control panel.
    • Be aware of wires connecting the microcontroller to the panel when removing the top lining.
  5. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement, Top Panel Buttons: paso 5, imagen 1 de 3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement, Top Panel Buttons: paso 5, imagen 2 de 3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement, Top Panel Buttons: paso 5, imagen 3 de 3
    • Disconnect microcontroller and top lining.
    • Ground yourself prior to disconnecting in order to avoid harming the inner electronics.
  6. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: paso 6, imagen 1 de 2 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: paso 6, imagen 2 de 2
    • Remove the two 11mm Phillips #1 screws from the top cover.
  7. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: paso 7, imagen 1 de 1
    • Use spudger to pop the control panel out.
  8. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: paso 8, imagen 1 de 3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: paso 8, imagen 2 de 3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: paso 8, imagen 3 de 3
    • Remove the four 11mm Phillips #1 screws from the control panel.
  9. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: paso 9, imagen 1 de 3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: paso 9, imagen 2 de 3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: paso 9, imagen 3 de 3
    • Remove the two 11mm Phillips #1 screws from the button panel.
    • Flip the screen assembly over and remove the button panel.
  10. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: paso 10, imagen 1 de 2 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: paso 10, imagen 2 de 2
    • Remove and replace buttons as necessary.
Conclusión
Megan Saunders
Miembro Desde 01/25/18
701 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S7-G5, Passmore Spring 2018 Miembro de USF Tampa, Team S7-G5, Passmore Spring 2018
USFT-PASSMORE-S18S7G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 229
