Saltar al contenido principal
  1. Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Accessories: paso 1, imagen 1 de 1
    • Remove the lid, steamer pot, and tray from the base unit.
  2. Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Bottom Cover: paso 2, imagen 1 de 2 Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Bottom Cover: paso 2, imagen 2 de 2
    • Flip the base unit over.
    • Remember to unplug your rice cooker before proceeding with teardown.
    • Remove the two Phillips screws.
    • Set aside all screws, keeping them in order by steps to help reconstruction.
    • Remove the bottom cover.
  3. Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Fuse: paso 3, imagen 1 de 2 Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Fuse: paso 3, imagen 2 de 2
    • Remove the three Phillips screws
    • Remove the fuse from the unit.
  4. Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Front Panel and Lever: paso 4, imagen 1 de 1
    • Flip the unit over.
    • Flip the unit back over.
  5. Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Front Panel and Lever: paso 5, imagen 1 de 3 Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Front Panel and Lever: paso 5, imagen 2 de 3 Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Front Panel and Lever: paso 5, imagen 3 de 3
    • Remove the single Phillips Screw.
    • Bend the tabs inward with needle nose pliers to mirror the shape of the hole below it.
    • Be careful not to bend these tabs too much or too far, for they break off easily if bent back and forth too many times.
    • Lift the lever out of the tab.
    • Carefully pull the front panel and lever out the front of the base.
  6. Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Circuit Board: paso 6, imagen 1 de 2 Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Circuit Board: paso 6, imagen 2 de 2
    • Remove the Phillips screw.
    • Carefully remove the circuit board from the front panel.
  7. Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Heating Coil: paso 7, imagen 1 de 1
    • Remove the nut using an adjustable wrench.
    • Remove the power connector extender.
    • Remove the three Phillips Screws.
    • This screw is slightly longer than the other two.
    • The heating coil will fall out after the removal of the last screw. Holding the coil while unscrewing the last screw is suggested to prevent damage to the coil.
  8. Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Thermomagnet: paso 8, imagen 1 de 2 Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Thermomagnet: paso 8, imagen 2 de 2
    • Bend the three tabs flat.
    • Remove the thermomagnet assembly from the heating coil.
Conclusión
Michael Chan
Miembro Desde 14/04/15
2,329 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 6-16, Maness Spring 2015 Miembro de Cal Poly, Team 6-16, Maness Spring 2015
CPSU-MANESS-S15S6G16
4 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 177
