Saltar al contenido principal
Oster CKSTSTMD5-W Disassembly
Qué necesitas
  1. Oster CKSTSTMD5-W Disassembly, Oster CKSTSTMD5-W Disassembly: paso 1, imagen 1 de 1
    • Remove the plastic steamer tiers and make sure the device is unplugged.
  2. Oster CKSTSTMD5-W Disassembly: paso 2, imagen 1 de 3 Oster CKSTSTMD5-W Disassembly: paso 2, imagen 2 de 3 Oster CKSTSTMD5-W Disassembly: paso 2, imagen 3 de 3
    • Flip the device upside down so that the sticker is facing upwards.
    • Using your hands, carefully pry out the four rubber feet from each of the corners.
  3. Oster CKSTSTMD5-W Disassembly: paso 3, imagen 1 de 2 Oster CKSTSTMD5-W Disassembly: paso 3, imagen 2 de 2
    • Using the JIS #1 screwdriver, remove four 12 mm screws from the four holes.
  4. Oster CKSTSTMD5-W Disassembly: paso 4, imagen 1 de 1
    • Once the four screws are removed, lift the bottom of the device off of the frame.
  5. Oster CKSTSTMD5-W Disassembly: paso 5, imagen 1 de 2 Oster CKSTSTMD5-W Disassembly: paso 5, imagen 2 de 2
    • Use a pair of scissors to cut the zip tie binding the blue and brown wires together.
  6. Oster CKSTSTMD5-W Disassembly: paso 6, imagen 1 de 3 Oster CKSTSTMD5-W Disassembly: paso 6, imagen 2 de 3 Oster CKSTSTMD5-W Disassembly: paso 6, imagen 3 de 3
    • Using a socket wrench with a 7 mm bit, unscrew the nut from the center of the metal ring.
  7. Oster CKSTSTMD5-W Disassembly: paso 7, imagen 1 de 1
    • Remove the nut and the two washers from the center bolt.
  8. Oster CKSTSTMD5-W Disassembly: paso 8, imagen 1 de 2 Oster CKSTSTMD5-W Disassembly: paso 8, imagen 2 de 2
    • Lift off the metal brace from the bolt in the center of the device.
  9. Oster CKSTSTMD5-W Disassembly: paso 9, imagen 1 de 2 Oster CKSTSTMD5-W Disassembly: paso 9, imagen 2 de 2
    • From the center of the device, carefully grab the blue wire and lift the thermal fuse from its socket.
  10. Oster CKSTSTMD5-W Disassembly: paso 10, imagen 1 de 3 Oster CKSTSTMD5-W Disassembly: paso 10, imagen 2 de 3 Oster CKSTSTMD5-W Disassembly: paso 10, imagen 3 de 3
    • Using your hands, carefully lift the wires over the center bolt so that they are out of the way.
  11. Oster CKSTSTMD5-W Disassembly: paso 11, imagen 1 de 2 Oster CKSTSTMD5-W Disassembly: paso 11, imagen 2 de 2
    • Using your index finger, carefully pry the metal sheeting out from under the wires.
  12. Oster CKSTSTMD5-W Disassembly: paso 12, imagen 1 de 3 Oster CKSTSTMD5-W Disassembly: paso 12, imagen 2 de 3 Oster CKSTSTMD5-W Disassembly: paso 12, imagen 3 de 3
    • Using the JIS #1 screwdriver, remove the two 12 mm screws from the left side of the device.
    • Lift off the white plastic brace.
  13. Oster CKSTSTMD5-W Disassembly: paso 13, imagen 1 de 1
    • Lift the white power cord out of its socket.
  14. Oster CKSTSTMD5-W Disassembly: paso 14, imagen 1 de 3 Oster CKSTSTMD5-W Disassembly: paso 14, imagen 2 de 3 Oster CKSTSTMD5-W Disassembly: paso 14, imagen 3 de 3
    • On the left-hand side of the device, carefully remove the indicator light from its place next to the timer by pulling on the heat protector covering the brown wire.
    • Be careful to ensure the bulb stays attached to the wire.
  15. Oster CKSTSTMD5-W Disassembly: paso 15, imagen 1 de 2 Oster CKSTSTMD5-W Disassembly: paso 15, imagen 2 de 2
    • Using the JIS #1 screwdriver, remove the two 12 mm screws attached on each side of the timer.
  16. Oster CKSTSTMD5-W Disassembly: paso 16, imagen 1 de 3 Oster CKSTSTMD5-W Disassembly: paso 16, imagen 2 de 3 Oster CKSTSTMD5-W Disassembly: paso 16, imagen 3 de 3
    • Using your hands, carefully lift the white plastic barrier out of the device from the right side of the timer.
    • Be careful not to impede the blue and brown wires connecting the heating element to the timer.
  17. Oster CKSTSTMD5-W Disassembly: paso 17, imagen 1 de 2 Oster CKSTSTMD5-W Disassembly: paso 17, imagen 2 de 2
    • Rotate the device so that the dial faces you.
    • Using the plastic opening tool, pry the white dial out of the timer socket.
  18. Oster CKSTSTMD5-W Disassembly: paso 18, imagen 1 de 1
    • Pull the white dial the rest of the way out of the socket.
  19. Oster CKSTSTMD5-W Disassembly: paso 19, imagen 1 de 2 Oster CKSTSTMD5-W Disassembly: paso 19, imagen 2 de 2
    • Using the JIS #1 screwdriver, remove the two 12 mm screws from the top and bottom of the timer socket.
  20. Oster CKSTSTMD5-W Disassembly: paso 20, imagen 1 de 1
    • Using your fingers, pry out the black timer socket from the front hole.
  21. Oster CKSTSTMD5-W Disassembly: paso 21, imagen 1 de 2 Oster CKSTSTMD5-W Disassembly: paso 21, imagen 2 de 2
    • Using your hands, carefully lift the timer out of the socket and away from the device.
    • Be careful not to pull too hard as to not break the wire connection.
  22. Oster CKSTSTMD5-W Disassembly: paso 22, imagen 1 de 2 Oster CKSTSTMD5-W Disassembly: paso 22, imagen 2 de 2
    • Using the JIS #1 screwdriver, remove the two 4.3 mm screws from the right and left side of the timer.
    • Using your hands, lift off the black plastic cover.
  23. Oster CKSTSTMD5-W Disassembly: paso 23, imagen 1 de 3 Oster CKSTSTMD5-W Disassembly: paso 23, imagen 2 de 3 Oster CKSTSTMD5-W Disassembly: paso 23, imagen 3 de 3
  24. Oster CKSTSTMD5-W Disassembly: paso 24, imagen 1 de 2 Oster CKSTSTMD5-W Disassembly: paso 24, imagen 2 de 2
    • Using the plastic opening tool, bend the 3 metal braces towards the outside of the timer so that the metal fits through the slots.
  25. Oster CKSTSTMD5-W Disassembly: paso 25, imagen 1 de 2 Oster CKSTSTMD5-W Disassembly: paso 25, imagen 2 de 2
    • Lift the silver cover off of the timer.
  26. Oster CKSTSTMD5-W Disassembly: paso 26, imagen 1 de 1
    • Lift the metal silver plate off of the timer.
  27. Oster CKSTSTMD5-W Disassembly: paso 27, imagen 1 de 2 Oster CKSTSTMD5-W Disassembly: paso 27, imagen 2 de 2
    • Using the JIS #1 screwdriver, remove the single 4.3mm screw from the top center of the timer.
  28. Oster CKSTSTMD5-W Disassembly: paso 28, imagen 1 de 3 Oster CKSTSTMD5-W Disassembly: paso 28, imagen 2 de 3 Oster CKSTSTMD5-W Disassembly: paso 28, imagen 3 de 3
    • Lift the black plastic casing out from in between the front and back of the timer.
  29. Oster CKSTSTMD5-W Disassembly: paso 29, imagen 1 de 2 Oster CKSTSTMD5-W Disassembly: paso 29, imagen 2 de 2
    • Rotate the timer 90 degrees to the left so that you can see it from the side.
    • Lift the silver back casing off of the timer.
Conclusión
Documentos Adjuntos
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 248
