Saltar al contenido principal
Oster Blend-N-Go My Blend Drinking Lid Seal Replacement
Qué necesitas
  1. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Blender Bottle: paso 1, imagen 1 de 2 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Blender Bottle: paso 1, imagen 2 de 2
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: paso 2, imagen 1 de 3 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: paso 2, imagen 2 de 3 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: paso 2, imagen 3 de 3
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
  3. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Drinking Lid Assembly: paso 3, imagen 1 de 1
    • After removing the blade assembly from the blender bottle, ensure that your drinking lid assembly has its seal placed in the seal bed.
  4. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: paso 4, imagen 1 de 3 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: paso 4, imagen 2 de 3 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: paso 4, imagen 3 de 3
    • Grab the blender bottle with one hand and the drinking lid assembly with the other.
    • Place the drinking lid assembly onto the blender bottle and twist it clockwise until it is tight around the blender bottle.
  5. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Drinking Lid Seal: paso 5, imagen 1 de 1
    • After separating the drinking lid assembly from the blender bottle, position the plastic opening tool on either side of the seal in the drinking lid assembly.
    • Wedge the tool between seal and seal seat wall.
  6. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: paso 6, imagen 1 de 2 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: paso 6, imagen 2 de 2
    • Gently pry the seal up while lifting seal out of the seal seat.
  7. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: paso 7, imagen 1 de 2 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: paso 7, imagen 2 de 2
    • Press new seal into seal seat with finger.
Conclusión
Una persona más ha completado esta guía.
Paul Long
Miembro Desde 08/27/15
710 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 12-6, Blackwell Fall 2015 Miembro de USF Tampa, Team 12-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G6
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 837
