Saltar al contenido principal
Oster Blend-N-Go My Blend Drinking Lid Assembly Replacement
  1. Oster Blend-N-Go My Blend Drinking Lid Assembly Replacement, Blender Bottle: paso 1, imagen 1 de 2 Oster Blend-N-Go My Blend Drinking Lid Assembly Replacement, Blender Bottle: paso 1, imagen 2 de 2
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Oster Blend-N-Go My Blend Drinking Lid Assembly Replacement: paso 2, imagen 1 de 3 Oster Blend-N-Go My Blend Drinking Lid Assembly Replacement: paso 2, imagen 2 de 3 Oster Blend-N-Go My Blend Drinking Lid Assembly Replacement: paso 2, imagen 3 de 3
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
  3. Oster Blend-N-Go My Blend Drinking Lid Assembly Replacement, Drinking Lid Assembly: paso 3, imagen 1 de 1
    • After removing the blade assembly from the blender bottle, ensure that your drinking lid assembly has its seal placed in the seal bed.
  4. Oster Blend-N-Go My Blend Drinking Lid Assembly Replacement: paso 4, imagen 1 de 3 Oster Blend-N-Go My Blend Drinking Lid Assembly Replacement: paso 4, imagen 2 de 3 Oster Blend-N-Go My Blend Drinking Lid Assembly Replacement: paso 4, imagen 3 de 3
    • Grab the blender bottle with one hand and the drinking lid assembly with the other.
    • Place the drinking lid assembly onto the blender bottle and twist it clockwise until it is tight around the blender bottle.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 12-6, Blackwell Fall 2015 Miembro de USF Tampa, Team 12-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G6
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 367
