Saltar al contenido principal
Oster Blend-N-Go My Blend Blade Assembly Seal Replacement
Qué necesitas
  1. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blender Bottle: paso 1, imagen 1 de 2 Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blender Bottle: paso 1, imagen 2 de 2
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: paso 2, imagen 1 de 3 Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: paso 2, imagen 2 de 3 Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: paso 2, imagen 3 de 3
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
  3. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blade Assembly: paso 3, imagen 1 de 1
    • After removing the blade assembly from the blender bottle, ensure your blade assembly has its seal placed in the seal bed.
  4. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blade Assembly Seal: paso 4, imagen 1 de 1
    • After separating the blade assembly from the blender bottle, position the plastic opening tool on either side of the seal in the blade assembly.
    • Wedge tool between seal and seal seat wall.
  5. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: paso 5, imagen 1 de 1
    • Gently pry the seal up while lifting seal out of the seal seat.
  6. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: paso 6, imagen 1 de 2 Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: paso 6, imagen 2 de 2
    • Place and press the new seal into seal seat with finger.
Conclusión
3 personas más completaron esta guía.
Paul Long
Miembro Desde 08/27/15
710 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 12-6, Blackwell Fall 2015 Miembro de USF Tampa, Team 12-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G6
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 18
Todo El Tiempo: 1,907
