Saltar al contenido principal
Oster Blend-N-Go My Blend Blade Assembly Replacement
  1. Oster Blend-N-Go My Blend Blade Assembly Replacement, Blender Bottle: paso 1, imagen 1 de 2 Oster Blend-N-Go My Blend Blade Assembly Replacement, Blender Bottle: paso 1, imagen 2 de 2
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Oster Blend-N-Go My Blend Blade Assembly Replacement: paso 2, imagen 1 de 3 Oster Blend-N-Go My Blend Blade Assembly Replacement: paso 2, imagen 2 de 3 Oster Blend-N-Go My Blend Blade Assembly Replacement: paso 2, imagen 3 de 3
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
  3. Oster Blend-N-Go My Blend Blade Assembly Replacement, Blade Assembly: paso 3, imagen 1 de 1
    • After removing the blade assembly from the blender bottle, ensure your blade assembly has its seal placed in the seal bed.
Conclusión
Una persona más ha completado esta guía.
Paul Long
Miembro Desde 08/27/15
710 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 12-6, Blackwell Fall 2015 Miembro de USF Tampa, Team 12-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G6
3 Miembros
5 Guías creadas
2 comentarios
I’m confused, these are the steps you have to go through every single time you use this blender to blend something. This isn’t really a “replacement” process here. If someone needs to repair a cracked blade assembly or buy a new one, how would they do that?
Alan M - Contestar
This process is not helpful at all. I followed as instructed but the blade is not moving at all?! What is going on? Pls provide better HELP INSTRUCTIONS.
Fareda Edwards - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 28
Todo El Tiempo: 3,586
