Saltar al contenido principal
Oster BLSTSS-PZO Power Cord Replacement
Qué necesitas
  1. Oster BLSTSS-PZO  Power Cord Replacement, Circuitboard: paso 1, imagen 1 de 1
    • Use the prying tools to open the four plastic screw holes on the bottom of the blender.
  2. Oster BLSTSS-PZO  Power Cord Replacement: paso 2, imagen 1 de 1
    • Use the Phillips #1 Screwdriver to unscrew the four 16 mm screws and remove the plastic bottom.
  3. Oster BLSTSS-PZO  Power Cord Replacement: paso 3, imagen 1 de 1
    • Gently remove the circuit board.
  4. Oster BLSTSS-PZO  Power Cord Replacement: paso 4, imagen 1 de 2 Oster BLSTSS-PZO  Power Cord Replacement: paso 4, imagen 2 de 2
    • Use the spudger to detach the black wire from the circuit board.
    • Repeat for yellow wire.
  5. Oster BLSTSS-PZO  Power Cord Replacement: paso 5, imagen 1 de 3 Oster BLSTSS-PZO  Power Cord Replacement: paso 5, imagen 2 de 3 Oster BLSTSS-PZO  Power Cord Replacement: paso 5, imagen 3 de 3
    • Use the Phillips #1 to remove the four 8mm screws.
    • Use the medal spudger to detach the circuit board from the buttons.
    • Gently pull and release circuit board from buttons.
  6. Oster BLSTSS-PZO  Power Cord Replacement, Power Cord: paso 6, imagen 1 de 3 Oster BLSTSS-PZO  Power Cord Replacement, Power Cord: paso 6, imagen 2 de 3 Oster BLSTSS-PZO  Power Cord Replacement, Power Cord: paso 6, imagen 3 de 3
    • Locate petal prong on the end of the power cord.
    • Bend metal prong until it's straight with your finger.
  7. Oster BLSTSS-PZO  Power Cord Replacement: paso 7, imagen 1 de 2 Oster BLSTSS-PZO  Power Cord Replacement: paso 7, imagen 2 de 2
    • Spring will pop out when you pull out metal prong
    • Pull prong out of the hole.
  8. Oster BLSTSS-PZO  Power Cord Replacement: paso 8, imagen 1 de 3 Oster BLSTSS-PZO  Power Cord Replacement: paso 8, imagen 2 de 3 Oster BLSTSS-PZO  Power Cord Replacement: paso 8, imagen 3 de 3
    • Pinch plastic prongs on base of blender to remove plastic securing device.
    • Remove plastic securing device.
    • Pull power cord out of blender base.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 7
Todo El Tiempo: 196
