Introducción
This repair is challenging because the wire that acts as the spring is difficult to bend into the correct shape.
Qué necesitas
Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
Press down on the toaster handle to access to the grabber spring located behind the large metal plate.
2 personas más completaron esta guía.
