Saltar al contenido principal
Oster 3905 Lever Spring Replacement
Qué necesitas
  1. Oster 3905 Lever Spring Replacement, Slot Levers: paso 1, imagen 1 de 1
    • Firmly grip your hand around the slot lever.
  2. Oster 3905 Lever Spring Replacement: paso 2, imagen 1 de 1
    • Stabilize the toaster by placing your hand on top.
  3. Oster 3905 Lever Spring Replacement: paso 3, imagen 1 de 2 Oster 3905 Lever Spring Replacement: paso 3, imagen 2 de 2
    • Forcefully pull the slot lever away from the toaster by keeping parallel to the table.
  4. Oster 3905 Lever Spring Replacement: paso 4, imagen 1 de 1
    • Both slot levers can be removed.
  5. Oster 3905 Lever Spring Replacement, Outer Shell: paso 5, imagen 1 de 1
    • Place the toaster upside down so the bottom is facing the ceiling.
  6. Oster 3905 Lever Spring Replacement: paso 6, imagen 1 de 2 Oster 3905 Lever Spring Replacement: paso 6, imagen 2 de 2
    • Take off both rubber feet using a small metal spudger.
    • Wedge a spudger under the feet and pull up to pop off.
  7. Oster 3905 Lever Spring Replacement: paso 7, imagen 1 de 1
    • Use a PH#2 screw bit to remove eight 12mm screws that are located around the perimeter.
    • There are two screws under the rubber feet.
  8. Oster 3905 Lever Spring Replacement: paso 8, imagen 1 de 1
    • Place the toaster right side up.
  9. Oster 3905 Lever Spring Replacement: paso 9, imagen 1 de 2 Oster 3905 Lever Spring Replacement: paso 9, imagen 2 de 2
    • Grab the outer shell firmly and pull up towards the face of the toaster.
  10. Oster 3905 Lever Spring Replacement: paso 10, imagen 1 de 1
    • For this part, you might need to wiggle the toaster to get the outer shell off.
    • The shell will not completely come off until the motherboard is removed in the next step.
  11. Oster 3905 Lever Spring Replacement: paso 11, imagen 1 de 3 Oster 3905 Lever Spring Replacement: paso 11, imagen 2 de 3 Oster 3905 Lever Spring Replacement: paso 11, imagen 3 de 3
    • Use a J1 screw bit to unscrew eight 8mm screws from the motherboard.
  12. Oster 3905 Lever Spring Replacement: paso 12, imagen 1 de 2 Oster 3905 Lever Spring Replacement: paso 12, imagen 2 de 2
    • Take out the grey “cancel” and “bagel” buttons from the shell.
  13. Oster 3905 Lever Spring Replacement, Lever Spring: paso 13, imagen 1 de 2 Oster 3905 Lever Spring Replacement, Lever Spring: paso 13, imagen 2 de 2
    • Use the plastic opening tool to remove the top metal panel by prying the 4 top metal tabs upwards. They will be able to slide through the openings and be pulled upwards.
  14. Oster 3905 Lever Spring Replacement: paso 14, imagen 1 de 2 Oster 3905 Lever Spring Replacement: paso 14, imagen 2 de 2
    • Once the top metal panel is unhooked, lift and let it hang off the side of the toaster.
  15. Oster 3905 Lever Spring Replacement: paso 15, imagen 1 de 3 Oster 3905 Lever Spring Replacement: paso 15, imagen 2 de 3 Oster 3905 Lever Spring Replacement: paso 15, imagen 3 de 3
    • Use a metal spudger to pry the 8 tabs upwards along the metal that separates the two slots.
    • Pull the metal spacer upwards to release from the toaster.
  16. Oster 3905 Lever Spring Replacement: paso 16, imagen 1 de 2 Oster 3905 Lever Spring Replacement: paso 16, imagen 2 de 2
    • Remove the spring wrapped around a metal rod at the front of the toaster, located behind the white plastic lever holder.
Conclusión
Una persona más ha completado esta guía.
Sydney Alcaraz
Miembro Desde 09/12/16
601 Reputación
3 Guías creadas
Equipo
CSU Fullerton, Team 2-1, Bruce Fall 2016 Miembro de CSU Fullerton, Team 2-1, Bruce Fall 2016
CSUF-BRUCE-F16S2G1
5 Miembros
6 Guías creadas
2 comentarios
Where's the fix?
D Unger - Contestar
Yeah. You just remove the spring? And then what? Surely removing the spring is not the fix.
kryshu - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 12
Todo El Tiempo: 2,923
