Saltar al contenido principal
Oster 16-Speed Blender Power Cord Replacement
Qué necesitas
  1. Oster 16-Speed Blender Power Cord Replacement, Fan and Motor: paso 1, imagen 1 de 2 Oster 16-Speed Blender Power Cord Replacement, Fan and Motor: paso 1, imagen 2 de 2
    • Remove the Blender Container from the Blender Base.
  2. Oster 16-Speed Blender Power Cord Replacement: paso 2, imagen 1 de 2 Oster 16-Speed Blender Power Cord Replacement: paso 2, imagen 2 de 2
    • Flip the blender so the bottom is facing you.
  3. Oster 16-Speed Blender Power Cord Replacement: paso 3, imagen 1 de 3 Oster 16-Speed Blender Power Cord Replacement: paso 3, imagen 2 de 3 Oster 16-Speed Blender Power Cord Replacement: paso 3, imagen 3 de 3
    • Unscrew the 16mm screws located on the plastic bottom from the blender base using a Phillips #2 screwdriver.
  4. Oster 16-Speed Blender Power Cord Replacement: paso 4, imagen 1 de 2 Oster 16-Speed Blender Power Cord Replacement: paso 4, imagen 2 de 2
    • Remove the plastic bottom from the base of the blender.
  5. Oster 16-Speed Blender Power Cord Replacement: paso 5, imagen 1 de 2 Oster 16-Speed Blender Power Cord Replacement: paso 5, imagen 2 de 2
    • Holding the center of the fan, grip the knob in the center of the top of the blender with a wrench and twist the wrench counterclockwise.
  6. Oster 16-Speed Blender Power Cord Replacement: paso 6, imagen 1 de 1
    • Carefully remove the motor and fan from the base of the blender.
  7. Oster 16-Speed Blender Power Cord Replacement: paso 7, imagen 1 de 3 Oster 16-Speed Blender Power Cord Replacement: paso 7, imagen 2 de 3 Oster 16-Speed Blender Power Cord Replacement: paso 7, imagen 3 de 3
    • Now, gently pull the white wire that is connected to the base and the motor.
    • Be careful, as there is a spring behind the contact points, that might try to shoot out and hurt you.
  8. Oster 16-Speed Blender Power Cord Replacement: paso 8, imagen 1 de 3 Oster 16-Speed Blender Power Cord Replacement: paso 8, imagen 2 de 3 Oster 16-Speed Blender Power Cord Replacement: paso 8, imagen 3 de 3
    • Now, turn the motor over, and remove the black wire from the motor.
    • Again, be warned as the is another spring that wants to shoot out and hurt you here as well.
  9. Oster 16-Speed Blender Power Cord Replacement: paso 9, imagen 1 de 2 Oster 16-Speed Blender Power Cord Replacement: paso 9, imagen 2 de 2
    • Now de-solder the yellow wire from circuit board. De-solder the wire following these instructions.
    • Be careful, as there is another, black wire, nearby that you do not want to de-solder.
  10. Oster 16-Speed Blender Power Cord Replacement, Circuit Board: paso 10, imagen 1 de 3 Oster 16-Speed Blender Power Cord Replacement, Circuit Board: paso 10, imagen 2 de 3 Oster 16-Speed Blender Power Cord Replacement, Circuit Board: paso 10, imagen 3 de 3
    • Locate the four 11mm screws in the circuit board.
    • Unscrew the four screws using the Phillips #1 screwdriver.
  11. Oster 16-Speed Blender Power Cord Replacement: paso 11, imagen 1 de 2 Oster 16-Speed Blender Power Cord Replacement: paso 11, imagen 2 de 2
    • Desolder the circuit board from the base at the indicated point, following the directions by clicking here.
    • Now separate the circuit board from the base.
  12. Oster 16-Speed Blender Power Cord Replacement: paso 12, imagen 1 de 3 Oster 16-Speed Blender Power Cord Replacement: paso 12, imagen 2 de 3 Oster 16-Speed Blender Power Cord Replacement: paso 12, imagen 3 de 3
    • You will see that the circuit board is still attached by a red wire and a black wire.
    • Flip the circuit board back over and desolder at the indicated points following the directions given here.
  13. Oster 16-Speed Blender Power Cord Replacement, Power Cord: paso 13, imagen 1 de 1
    • You do not have to completely remove the circuit board to replace the power cord. You can, if desired, skip the steps of de-soldering the yellow wire, and the circuit board from the base.
    • De-solder the black wire from the circuit board, and then carefully remove the black wire.
    • Now you can solder on the new power cord.
Conclusión
4 personas más completaron esta guía.
Dana
Miembro Desde 04/14/14
773 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 12-37, Maness Spring 2014 Miembro de Cal Poly, Team 12-37, Maness Spring 2014
CPSU-MANESS-S14S12G37
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 29
Todo El Tiempo: 3,157
