Qué necesitas
Now de-solder the yellow wire from circuit board. De-solder the wire following these instructions.
Locate the four 11mm screws in the circuit board.
Unscrew the four screws using the Phillips #1 screwdriver.
De-solder the black wire from the circuit board, and then carefully remove the black wire.
Now you can solder on the new power cord.
4 personas más completaron esta guía.
