Saltar al contenido principal
Introducción
This guide shows how to disassemble the Osram Lightify gateway.
  1. Remove the front using a metal spudger.
    • Remove the front using a metal spudger.
    • Once you can get your fingers in, remove the rest using your hand.
  2. On the back of the front cover, remove the white plastic using a metal spudger. Remove the PCB using a spudger
    • On the back of the front cover, remove the white plastic using a metal spudger.
    • Remove the PCB using a spudger
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Once the PCB is removed, use a Torx T9 screwdriver to unscrew and remove the power supply. Remove the screws holding on the back cover with a Torx T9 screwdriver and remove the back cover.
    • Once the PCB is removed, use a Torx T9 screwdriver to unscrew and remove the power supply.
    • Remove the screws holding on the back cover with a Torx T9 screwdriver and remove the back cover.
    • all the screws are the same. they can be mixed with no problem.
  5. Remove the button by grabbing the tab over the button and pulling it out. it will not come out if the button is not depressed. Remove both metal sheets. when its at an angle, push it in a little and then pull it up so that it is pointing straight up. then, you can push it through.
    • Remove the button by grabbing the tab over the button and pulling it out.
    • it will not come out if the button is not depressed.
    • Remove both metal sheets. when its at an angle, push it in a little and then pull it up so that it is pointing straight up. then, you can push it through.
Conclusión
Una persona más ha completado esta guía.
Aiden Baker
Miembro Desde 19/09/15
12,050 Reputación
22 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 95
