Saltar al contenido principal
Oreva FX-82MS Battery Replacement
Qué necesitas
  1. Oreva FX-82MS Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the calculator by pressing the [Shift] button and then press the [AC][OFF] button, (while keeping the [Shift] button pressed down).
  2. Oreva FX-82MS Battery Replacement: paso 2, imagen 1 de 2 Oreva FX-82MS Battery Replacement: paso 2, imagen 2 de 2
    • Flip the calculator over so that the back panel faces up.
    • Use a Phillips #0 screwdriver to remove six, 1.2 mm screws starting from the upper right corner.
  3. Oreva FX-82MS Battery Replacement: paso 3, imagen 1 de 2 Oreva FX-82MS Battery Replacement: paso 3, imagen 2 de 2
    • Remove the back cover and put it to the side.
  4. Oreva FX-82MS Battery Replacement: paso 4, imagen 1 de 2 Oreva FX-82MS Battery Replacement: paso 4, imagen 2 de 2
    • Remove the two old batteries from the slots.
    • Be gentle when removing the batteries to avoid damaging the connectors.
  5. Oreva FX-82MS Battery Replacement: paso 5, imagen 1 de 3 Oreva FX-82MS Battery Replacement: paso 5, imagen 2 de 3 Oreva FX-82MS Battery Replacement: paso 5, imagen 3 de 3
    • Place the two new AAA batteries into the calculator, one by one.
    • Be sure that the direction of the + and - signs on your battery match the signs at the bottom of the battery compartment.
    • Place the case on back of the calculator.
  6. Oreva FX-82MS Battery Replacement: paso 6, imagen 1 de 2 Oreva FX-82MS Battery Replacement: paso 6, imagen 2 de 2
    • Use a Phillips #0 screwdriver to replace the 1.2 mm screws on the back case.
  7. Oreva FX-82MS Battery Replacement: paso 7, imagen 1 de 1
    • Reset the calculator by pressing [ON].
    • Press the [shift] button.
    • Press the [9] [CLR] button to clear the data.
    • Press the [3][ALL] button option.
    • Press [=] [yes] button to agree.
    • Press [AC] key to reset.
Conclusión
Una persona más ha completado esta guía.
Prarthit patel
Miembro Desde 07/02/22
175 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 31
Ultimos 30 días: 137
Todo El Tiempo: 1,035
