Saltar al contenido principal
Oregon Scientific RM318PA Focus Knob Replacement
Qué necesitas
  1. Oregon Scientific RM318PA Focus Knob Replacement, A/C Adapter: paso 1, imagen 1 de 3 Oregon Scientific RM318PA Focus Knob Replacement, A/C Adapter: paso 1, imagen 2 de 3 Oregon Scientific RM318PA Focus Knob Replacement, A/C Adapter: paso 1, imagen 3 de 3
    • Hold Clock so the screen is facing away from you.
    • Using your thumbs, push up on battery cover to remove.
    • With your other hand, pull down on the A/C Adapter jack to remove.
  2. Oregon Scientific RM318PA Focus Knob Replacement, Batteries: paso 2, imagen 1 de 1
    • Remove batteries by pushing a battery toward the spring.
    • Lift battery out at an angle. Repeat with second battery.
  3. Oregon Scientific RM318PA Focus Knob Replacement, Projection Arm: paso 3, imagen 1 de 3 Oregon Scientific RM318PA Focus Knob Replacement, Projection Arm: paso 3, imagen 2 de 3 Oregon Scientific RM318PA Focus Knob Replacement, Projection Arm: paso 3, imagen 3 de 3
    • Use a Phillips #00 Screwdriver to remove the four (4) screws from the back of the projection arm.
    • Once screws are removed, lift the back up and off of the projection arm.
  4. Oregon Scientific RM318PA Focus Knob Replacement: paso 4, imagen 1 de 2 Oregon Scientific RM318PA Focus Knob Replacement: paso 4, imagen 2 de 2
    • Use a Phillips #00 Screwdriver to remove two (2) screws from back of projection arm.
  5. Oregon Scientific RM318PA Focus Knob Replacement: paso 5, imagen 1 de 2 Oregon Scientific RM318PA Focus Knob Replacement: paso 5, imagen 2 de 2
    • Use a plastic opening tool to pry apart the front of the projection arm casing. Start at the top of the projection arm.
    • Once top is partially open, use a spudger to pry at the side of the projection arm.
  6. Oregon Scientific RM318PA Focus Knob Replacement, Focus Knob: paso 6, imagen 1 de 3 Oregon Scientific RM318PA Focus Knob Replacement, Focus Knob: paso 6, imagen 2 de 3 Oregon Scientific RM318PA Focus Knob Replacement, Focus Knob: paso 6, imagen 3 de 3
    • Turn the clock on its side. Slide the Focus Knob forward with your thumb.
    • The Focus Knob Component should now be free of Projection Arm.
    • Hold the Component in one hand and lift the Projection Beam up and away from the Focus Knob.
  7. Oregon Scientific RM318PA Focus Knob Replacement: paso 7, imagen 1 de 3 Oregon Scientific RM318PA Focus Knob Replacement: paso 7, imagen 2 de 3 Oregon Scientific RM318PA Focus Knob Replacement: paso 7, imagen 3 de 3
    • Loosen Focus Knob by turning the Focus Knob counterclockwise with your fingers.
    • If needed, add a SMALL amount of WD-40 to the base of the knob and continue turning Focus Knob.
    • Place replacement Focus Knob in socket and turn clockwise to secure.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 830
