Saltar al contenido principal
Introducción
The A/C Power Adapter enables the projector to be on continuously. Replacing this item could fix a malfunctioning projector.
  1. To access the A/C Power Adapter connection, remove the battery cover, located on the back of the clock. To access the A/C Power Adapter connection, remove the battery cover, located on the back of the clock.
    • To access the A/C Power Adapter connection, remove the battery cover, located on the back of the clock.
  2. To remove the battery compartment cover, slide the cover up towards the top of the clock while applying slight pressure. To remove the battery compartment cover, slide the cover up towards the top of the clock while applying slight pressure.
    • To remove the battery compartment cover, slide the cover up towards the top of the clock while applying slight pressure.
  3. Gently pull the A/C Power Adapter from the socket, to the left of the batteries.
    • Gently pull the A/C Power Adapter from the socket, to the left of the batteries.
  4. To plug in the A/C Power Adapter, insert the tip into the socket, located to the left of the batteries, and press firmly.
    • To plug in the A/C Power Adapter, insert the tip into the socket, located to the left of the batteries, and press firmly.
    • Be sure that you are inserting an A/C Power Adapter and not a D/C Power Adapter. Inserting the improper cord could cause damage to the device.
  5. Once the A/C Power Adapter tip is inserted in the socket, guide the cord through a notch directly below.
    • Once the A/C Power Adapter tip is inserted in the socket, guide the cord through a notch directly below.
Conclusión
i need operating manual for model no.rm318pa.please send to…gjgeoff1@outlook.fr
jean-guy geoffroy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 36
Todo El Tiempo: 1,898
