Saltar al contenido principal
Oregon Scientific Meep! X2 Cameras Replacement
Qué necesitas
  1. Oregon Scientific Meep! X2 Cameras Replacement, Rear Casing: paso 1, imagen 1 de 1
    • Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
  2. Oregon Scientific Meep! X2 Cameras Replacement: paso 2, imagen 1 de 3 Oregon Scientific Meep! X2 Cameras Replacement: paso 2, imagen 2 de 3 Oregon Scientific Meep! X2 Cameras Replacement: paso 2, imagen 3 de 3
    • You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device.
  3. Oregon Scientific Meep! X2 Cameras Replacement: paso 3, imagen 1 de 3 Oregon Scientific Meep! X2 Cameras Replacement: paso 3, imagen 2 de 3 Oregon Scientific Meep! X2 Cameras Replacement: paso 3, imagen 3 de 3
    • Use the plastic opening tools to undo the clips around the edges of the device.
  4. Oregon Scientific Meep! X2 Cameras Replacement, Cameras: paso 4, imagen 1 de 2 Oregon Scientific Meep! X2 Cameras Replacement, Cameras: paso 4, imagen 2 de 2
    • Slip the plastic opening tool under the white, square enclosure of the camera and lift upward to unhook the camera unit from the motherboard.
  5. Oregon Scientific Meep! X2 Cameras Replacement: paso 5, imagen 1 de 2 Oregon Scientific Meep! X2 Cameras Replacement: paso 5, imagen 2 de 2
    • Pry the second camera out of its slot with one of the plastic opening tools.
    • Be sure to undo the black adhesive foam from the metal casing in order to remove the camera properly.
  6. Oregon Scientific Meep! X2 Cameras Replacement: paso 6, imagen 1 de 1
    • Release the black security clip on the ribbon cable with your plastic opening tool.
    • Gently disconnect the gold ribbon cable from the motherboard. The two cameras will remain attached to the ribbon cable.
Conclusión
J'mel Henneman
Miembro Desde 01/20/15
864 Reputación
8 Guías creadas
Equipo
USF Tampa, Team 9-1, Blackwell Winter 2015 Miembro de USF Tampa, Team 9-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G1
3 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 203
