Saltar al contenido principal
Oregon Scientific Meep! X2 Battery Replacement
Qué necesitas
  1. Oregon Scientific Meep! X2 Battery Replacement, Rear Casing: paso 1, imagen 1 de 1
    • Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
  2. Oregon Scientific Meep! X2 Battery Replacement: paso 2, imagen 1 de 3 Oregon Scientific Meep! X2 Battery Replacement: paso 2, imagen 2 de 3 Oregon Scientific Meep! X2 Battery Replacement: paso 2, imagen 3 de 3
    • You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device.
  3. Oregon Scientific Meep! X2 Battery Replacement: paso 3, imagen 1 de 3 Oregon Scientific Meep! X2 Battery Replacement: paso 3, imagen 2 de 3 Oregon Scientific Meep! X2 Battery Replacement: paso 3, imagen 3 de 3
    • Use the plastic opening tools to undo the clips around the edges of the device.
  4. Oregon Scientific Meep! X2 Battery Replacement, Remove the ribbon cable.: paso 4, imagen 1 de 3 Oregon Scientific Meep! X2 Battery Replacement, Remove the ribbon cable.: paso 4, imagen 2 de 3 Oregon Scientific Meep! X2 Battery Replacement, Remove the ribbon cable.: paso 4, imagen 3 de 3
    • Gently unhook the black security clips to loosen the ribbon cable. Use one of the plastic opening tools.
    • Pull lightly on the ribbon cable to remove it.
  5. Oregon Scientific Meep! X2 Battery Replacement, Sever the adhesive glue on the battery.: paso 5, imagen 1 de 2 Oregon Scientific Meep! X2 Battery Replacement, Sever the adhesive glue on the battery.: paso 5, imagen 2 de 2
    • Use your spudger to separate the battery from the adhesive glue strips and plastic film.
  6. Oregon Scientific Meep! X2 Battery Replacement: paso 6, imagen 1 de 2 Oregon Scientific Meep! X2 Battery Replacement: paso 6, imagen 2 de 2
    • Use a soldering station to unsolder the battery wires from the motherboard.
    • In the case of screen or screen sensor replacement, disregard desoldering steps.
Conclusión
J'mel Henneman
Miembro Desde 01/20/15
864 Reputación
8 Guías creadas
Equipo
USF Tampa, Team 9-1, Blackwell Winter 2015 Miembro de USF Tampa, Team 9-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G1
3 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 1,465
