Saltar al contenido principal
Orbic Wonder Battery Replacement
Qué necesitas
  1. Orbic Wonder Battery Replacement, Battery: paso 1, imagen 1 de 3 Orbic Wonder Battery Replacement, Battery: paso 1, imagen 2 de 3 Orbic Wonder Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Remove two 2mm TR9 Torx screws from the bottoms of the device.
  2. Orbic Wonder Battery Replacement: paso 2, imagen 1 de 3 Orbic Wonder Battery Replacement: paso 2, imagen 2 de 3 Orbic Wonder Battery Replacement: paso 2, imagen 3 de 3
    • There is a border between the black phone backing and the silver screen.
    • Place the Jimmy in this border, and cautiously torque it back and forth to part the two halves.
    • When the halves are parted correctly, the gap should look like this.
    • Be careful to avoid damaging any connecting circuitry between the two halves.
  3. Orbic Wonder Battery Replacement: paso 3, imagen 1 de 3 Orbic Wonder Battery Replacement: paso 3, imagen 2 de 3 Orbic Wonder Battery Replacement: paso 3, imagen 3 de 3
    • Before continuing, tighten the anti-static wrist strap around your wrist and connect the alligator clips to a metal portion of the phone.
    • On the upper right side, there is a black ribbon cable in the shape of an “L”. Remove the single 1 mm Phillips #000 screw on the left side of the ribbon cable.
  4. Orbic Wonder Battery Replacement: paso 4, imagen 1 de 3 Orbic Wonder Battery Replacement: paso 4, imagen 2 de 3 Orbic Wonder Battery Replacement: paso 4, imagen 3 de 3
    • Use a pair of angled tweezers to carefully remove the metal casing of the ribbon cable.
    • Use a pair of angled tweezers to detach the black ribbon cable. This is done to unplug the battery.
  5. Orbic Wonder Battery Replacement: paso 5, imagen 1 de 3 Orbic Wonder Battery Replacement: paso 5, imagen 2 de 3 Orbic Wonder Battery Replacement: paso 5, imagen 3 de 3
    • There is a black flap on the bottom of the battery.
    • Using your fingers, pinch this flap and carefully pull the battery up and out of the phone.
Conclusión
2 personas más completaron esta guía.
3 comentarios
where do you buy the replacement battery at ?
ricotoomo - Contestar
Where can I buy a replacement battery
Robert Smith -
Thank you big help your smart
gansterms123 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 21
Ultimos 30 días: 92
Todo El Tiempo: 6,563
