Saltar al contenido principal
Optoma HD72 Projection Lamp Replacement
Qué necesitas
  1. Optoma HD72 Projection Lamp Replacement, Projection Lamp: paso 1, imagen 1 de 1
    • Use a Phillips screwdriver to loosen the single captive 2 mm screw that secures the small lamp panel on the lower case.
    • Remove the panel.
  2. Optoma HD72 Projection Lamp Replacement: paso 2, imagen 1 de 1
    • Use a Phillips screwdriver to loosen the two 2 mm screws on the bottom of the projection lamp housing.
  3. Optoma HD72 Projection Lamp Replacement: paso 3, imagen 1 de 2 Optoma HD72 Projection Lamp Replacement: paso 3, imagen 2 de 2
    • Lift the panel off of the device using the metal handle.
    • Disconnect the pink wires from the black plastic housing.
  4. Optoma HD72 Projection Lamp Replacement: paso 4, imagen 1 de 3 Optoma HD72 Projection Lamp Replacement: paso 4, imagen 2 de 3 Optoma HD72 Projection Lamp Replacement: paso 4, imagen 3 de 3
    • Use a Phillips #2 screwdriver to remove the four 2 mm screws that secure the lamp to its housing.
    • Remove the projection lamp casing by gently lifting the bulb from its housing.
  5. Optoma HD72 Projection Lamp Replacement: paso 5, imagen 1 de 2 Optoma HD72 Projection Lamp Replacement: paso 5, imagen 2 de 2
    • Once the bulb is out, replace it with another bulb and re-secure the housings in reverse order to this guide.
    • The second photo is what the completed bulb housing should look like.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 11
Todo El Tiempo: 40
