Saltar al contenido principal
Optoma HD72 Ballast Replacement
Qué necesitas
  1. Optoma HD72 Ballast Replacement, Upper Case: paso 1, imagen 1 de 2 Optoma HD72 Ballast Replacement, Upper Case: paso 1, imagen 2 de 2
    • Use a Phillips screwdriver to remove the five 2 mm screws on the underside of the device.
  2. Optoma HD72 Ballast Replacement: paso 2, imagen 1 de 1
    • Flip the device over and slightly lift the upper case, with care not to strain the two cables.
    • Disconnect the two cables that connect the top case to the motherboard.
    • Lift the upper case up and off.
  3. Optoma HD72 Ballast Replacement, Motherboard: paso 3, imagen 1 de 3 Optoma HD72 Ballast Replacement, Motherboard: paso 3, imagen 2 de 3 Optoma HD72 Ballast Replacement, Motherboard: paso 3, imagen 3 de 3
    • Disconnect all of the cables that are connected to the motherboard.
  4. Optoma HD72 Ballast Replacement: paso 4, imagen 1 de 1
    • Remove the four 2 mm Phillips screws that secure the motherboard.
    • Lift the motherboard up and out of the chassis.
  5. Optoma HD72 Ballast Replacement, Ballast: paso 5, imagen 1 de 3 Optoma HD72 Ballast Replacement, Ballast: paso 5, imagen 2 de 3 Optoma HD72 Ballast Replacement, Ballast: paso 5, imagen 3 de 3
    • Remove the two 2 mm Phillips screws that secure the power supply.
    • Remove the two 2 mm Phillips screws that secure the ballast to the power supply.
    • Disconnect the bundles of detachable wires from the ballast.
    • Lift the ballast out of the device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 13
Ultimos 30 días: 27
Todo El Tiempo: 42
