Saltar al contenido principal
Optoma HD20 Light Bulb Replacement
Qué necesitas
  1. Optoma HD20 Light Bulb Replacement, Rear Panel: paso 1, imagen 1 de 2 Optoma HD20 Light Bulb Replacement, Rear Panel: paso 1, imagen 2 de 2
    • Use a Phillips #1 screwdriver to loosen the screws that secure the panel on the bottom of the Optoma HD20.
  2. Optoma HD20 Light Bulb Replacement: paso 2, imagen 1 de 1
    • Lift the panel off of the device.
  3. Optoma HD20 Light Bulb Replacement, Light Bulb Casing: paso 3, imagen 1 de 1
    • Use a Phillips #1 screwdriver to loosen the two screws securing the black casing.
    • The screws don't come out all the way.
  4. Optoma HD20 Light Bulb Replacement: paso 4, imagen 1 de 3 Optoma HD20 Light Bulb Replacement: paso 4, imagen 2 de 3 Optoma HD20 Light Bulb Replacement: paso 4, imagen 3 de 3
    • Remove the light bulb casing from the device.
    • Steps 5-9 are unnecessary if the replacement light bulb comes with housing.
  5. Optoma HD20 Light Bulb Replacement, Light Bulb: paso 5, imagen 1 de 1
    • Remove the three 4.5 mm screws on the light bulb case.
  6. Optoma HD20 Light Bulb Replacement: paso 6, imagen 1 de 1
    • Carefully remove the light bulb insulator from the light bulb casing.
  7. Optoma HD20 Light Bulb Replacement: paso 7, imagen 1 de 1
    • Gently pull the wires off of the pins using tweezers.
  8. Optoma HD20 Light Bulb Replacement: paso 8, imagen 1 de 1
    • Remove the 4 screws on the back of the light bulb casing using a Phillips #1 screwdriver.
  9. Optoma HD20 Light Bulb Replacement: paso 9, imagen 1 de 2 Optoma HD20 Light Bulb Replacement: paso 9, imagen 2 de 2
    • Remove the casing, then gently pull out the old light bulb and replace it with the new one.
Conclusión
7 personas más completaron esta guía.
Trever
Miembro Desde 01/22/15
1,264 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 21-23, Maness Winter 2015 Miembro de Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Miembros
6 Guías creadas
5 comentarios
I recently replaced my bulb for the third time and the insulator had grown brittle I am guessing from the heat and it broke. I can't seem to find this part for sale anywhere. Does anyone know if is possible to purchase it?
Thomas - Contestar
The screws in step 8 are extremely hard to get off. I went and bought proper screwdrivers before even attempting since theyre small, but in a day I've only managed to get one off and I'm having to resort to other tactics, even using a drill to just grind the heads off.
dv01_ - Contestar
king@okinlamps.com
Need LAD60 20PCS
kingshen92 - Contestar
The manual says the new light won’t come back on until a lamp reset I’d done via menu , but how can you see the text if the light isn’t on?????
Taringajohn - Contestar
my hd 20 projects dull images i recently replaced my bulb for the first time successfully and i followed as per menu trying to bulb reset but it is not working and still image is dull how to solve the problem
kumar - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 20
Ultimos 30 días: 69
Todo El Tiempo: 11,433
