Saltar al contenido principal
Optoma HD20 Focal Lens Replacement
Qué necesitas
  1. Optoma HD20 Focal Lens Replacement, Disassembling Optoma HD20 Cover: paso 1, imagen 1 de 2 Optoma HD20 Focal Lens Replacement, Disassembling Optoma HD20 Cover: paso 1, imagen 2 de 2
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
  2. Optoma HD20 Focal Lens Replacement: paso 2, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
  3. Optoma HD20 Focal Lens Replacement: paso 3, imagen 1 de 1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
  4. Optoma HD20 Focal Lens Replacement: paso 4, imagen 1 de 1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
  5. Optoma HD20 Focal Lens Replacement, Focal Lens: paso 5, imagen 1 de 1
    • Use a Phillips #1 screwdriver to unscrew the small black 2 mm screw on the side of the focal lens.
  6. Optoma HD20 Focal Lens Replacement: paso 6, imagen 1 de 1
    • Remove the focal lens by twisting it clockwise until it comes off.
Conclusión
Una persona más ha completado esta guía.
Trever
Miembro Desde 01/22/15
1,264 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 21-23, Maness Winter 2015 Miembro de Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 25
Todo El Tiempo: 4,306
