Introducción
Use this guide to remove the fan from your Optoma HD20.
Qué necesitas
Twist the focal cap clockwise until it is fully extended.
Remove the focal cap by pulling it straight out.
6 personas más completaron esta guía.
6 comentarios
Very nice set of instructions! Excellent images and identification of items to remove. Thank you!
Do you know where to get this fan for replacement? Having trouble finding a parts list.
Small fan is GB1245PKVX-8, large fan is KDE1285PTV1
I am trying to determine if the fan works or not. Should the fan come on when there is no bulb in the projector? I removed the bulb when it burned up and I am not sure whether it was due to a failed fan or simply the bulb.
Amazing! Thank you!!! Took a bit of effort to get the fan but in the end it worked like a charm!! Thank you for saving money!!!!
