Saltar al contenido principal
Optoma HD20 Air Filter Replacement
Qué necesitas
  1. Optoma HD20 Air Filter Replacement, Disassembling Optoma HD20 Cover: paso 1, imagen 1 de 2 Optoma HD20 Air Filter Replacement, Disassembling Optoma HD20 Cover: paso 1, imagen 2 de 2
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
  2. Optoma HD20 Air Filter Replacement: paso 2, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
  3. Optoma HD20 Air Filter Replacement: paso 3, imagen 1 de 1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
  4. Optoma HD20 Air Filter Replacement: paso 4, imagen 1 de 1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
  5. Optoma HD20 Air Filter Replacement, Air Filter: paso 5, imagen 1 de 3 Optoma HD20 Air Filter Replacement, Air Filter: paso 5, imagen 2 de 3 Optoma HD20 Air Filter Replacement, Air Filter: paso 5, imagen 3 de 3
    • Carefully peel off each air filter from the device
    • Pull up on the air filter to remove it.
  6. Optoma HD20 Air Filter Replacement: paso 6, imagen 1 de 1
    • Remove the air filter from the device.
    • Try not to deposit dirt from the air filter into the inside of the device.
Conclusión
Una persona más ha completado esta guía.
Trever
Miembro Desde 01/22/15
1,264 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 21-23, Maness Winter 2015 Miembro de Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Miembros
6 Guías creadas
Un comentario
There were no filters where the photos indicate.
Michael - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 49
Todo El Tiempo: 12,071
