Saltar al contenido principal
Oppo X9000 Chassis Replacement
Qué necesitas
  1. Oppo X9000 Chassis Replacement, Removing the Back Cover: paso 1, imagen 1 de 2 Oppo X9000 Chassis Replacement, Removing the Back Cover: paso 1, imagen 2 de 2
    • Turn the phone over so that you are facing the back side of the phone.
    • With your fingers, pry the back cover up starting from the top of the phone near the headphone jack and camera.
    • Completely remove the back cover by moving down the sides and bottom with your fingers.
  2. Oppo X9000 Chassis Replacement, Removing the Battery: paso 2, imagen 1 de 1
    • With your finger, remove the battery from the phone by gently lifting the top-right corner nearest to the camera.
  3. Oppo X9000 Chassis Replacement, Remove the Back Panel Screws: paso 3, imagen 1 de 2 Oppo X9000 Chassis Replacement, Remove the Back Panel Screws: paso 3, imagen 2 de 2
    • Remove the twelve exposed 3.6 mm Phillips screws on the rear of the phone using the 3.6 mm Phillips screwdriver.
    • Store all the screws in a safe place where you will not lose them.
  4. Oppo X9000 Chassis Replacement, Remove the Rubber Stoppers: paso 4, imagen 1 de 2 Oppo X9000 Chassis Replacement, Remove the Rubber Stoppers: paso 4, imagen 2 de 2
    • Remove the three circular rubber screw covers on the back of the phone by slipping the spudger into the border between the rubber cover and the chassis. In one motion, pry the stopper out of the hole. This can take some force.
  5. Oppo X9000 Chassis Replacement, Remove the Newly Exposed Screws: paso 5, imagen 1 de 1
    • With the 3.6 mm Phillips screwdriver, remove the three newly exposed 3.6mm Phillips screws.
  6. Oppo X9000 Chassis Replacement, Lift off the Back Panel: paso 6, imagen 1 de 2 Oppo X9000 Chassis Replacement, Lift off the Back Panel: paso 6, imagen 2 de 2
    • Insert the plastic opening tool underneath the chassis near the power button and pry the chassis from the phone. This should take a little force.
Conclusión
4 personas más completaron esta guía.
James Kragh
Miembro Desde 10/14/14
1,602 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 4-45, Amido Fall 2014 Miembro de Cal Poly, Team 4-45, Amido Fall 2014
CPSU-AMIDO-F14S4G45
5 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 1,850
