Saltar al contenido principal
Oppo X9000 Battery Replacement
  1. Oppo X9000 Battery Replacement, Removing the Back Cover: paso 1, imagen 1 de 2 Oppo X9000 Battery Replacement, Removing the Back Cover: paso 1, imagen 2 de 2
    • Turn the phone over so that you are facing the back side of the phone.
    • With your fingers, pry the back cover up starting from the top of the phone near the headphone jack and camera.
    • Completely remove the back cover by moving down the sides and bottom with your fingers.
  2. Oppo X9000 Battery Replacement, Removing the Battery: paso 2, imagen 1 de 1
    • With your finger, remove the battery from the phone by gently lifting the top-right corner nearest to the camera.
Conclusión
14 personas más completaron esta guía.
James Kragh
Miembro Desde 10/14/14
1,602 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 4-45, Amido Fall 2014 Miembro de Cal Poly, Team 4-45, Amido Fall 2014
CPSU-AMIDO-F14S4G45
5 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 25
Todo El Tiempo: 4,069
