Saltar al contenido principal
Oontz Angle 3 ULTRA Driver Replacement
Qué necesitas
  1. Oontz Angle 3 ULTRA Driver Replacement, Back Panel: paso 1, imagen 1 de 3 Oontz Angle 3 ULTRA Driver Replacement, Back Panel: paso 1, imagen 2 de 3 Oontz Angle 3 ULTRA Driver Replacement, Back Panel: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Remove the two black rubber sheaths around the edges of the speaker.
    • Under the symbol-marked sheath there is a white rubber covering for the buttons. Peel this away to reveal the panel underneath.
    • On two corners of its triangular face there is a small divot, which allows you to use your fingernails or a pair of tweezers to grip and peel away the covering.
  2. Oontz Angle 3 ULTRA Driver Replacement: paso 2, imagen 1 de 3 Oontz Angle 3 ULTRA Driver Replacement: paso 2, imagen 2 de 3 Oontz Angle 3 ULTRA Driver Replacement: paso 2, imagen 3 de 3
    • Use a JIS #0 screwdriver to remove the six screws to expose the motherboard.
  3. Oontz Angle 3 ULTRA Driver Replacement: paso 3, imagen 1 de 3 Oontz Angle 3 ULTRA Driver Replacement: paso 3, imagen 2 de 3 Oontz Angle 3 ULTRA Driver Replacement: paso 3, imagen 3 de 3
    • Using a pair of tweezers, pinch and pull the rubber fillings obstructing the screws.
  4. Oontz Angle 3 ULTRA Driver Replacement: paso 4, imagen 1 de 3 Oontz Angle 3 ULTRA Driver Replacement: paso 4, imagen 2 de 3 Oontz Angle 3 ULTRA Driver Replacement: paso 4, imagen 3 de 3
    • Using a JIS #0 screwdriver, remove the 6 screws holding the backplate in.
    • Remove the back panel off of the device.
  5. Oontz Angle 3 ULTRA Driver Replacement, Driver: paso 5, imagen 1 de 1
    • Insert the Jimmy into the gap between the speaker's grill and the plastic enclosure.
    • Work the Jimmy around the gap to free it from the speaker enclosure.
    • The grill edges are sharp. Be careful and patient when performing this step to avoid injuring yourself.
  6. Oontz Angle 3 ULTRA Driver Replacement: paso 6, imagen 1 de 1
    Desoldering Pump
    $3.99
    • Locate the wires connecting to the driver. There will be a red wire connected to the driver’s positive terminal, and a black wire connected to the driver’s negative terminal.
    • During reassembly, it is important to orient the wires properly to avoid damage to the speaker and new drivers.
    • With your soldering iron and solder sucker, remove the solder connecting the wires to each terminal, and then gently pull the wires away from the terminals to free them.
    • For more information on soldering and desoldering connections, please read the How to Solder and Desolder Connections Guide.
  7. Oontz Angle 3 ULTRA Driver Replacement: paso 7, imagen 1 de 2 Oontz Angle 3 ULTRA Driver Replacement: paso 7, imagen 2 de 2
    • Remove the eight screws with the Phillips #0 screwdriver.
    • Gently push the driver from the rear out of the enclosure to remove it.
Conclusión
Una persona más ha completado esta guía.
3Guía Comentarios
Where can i purchase replacement speaker
John Benedict Sumallo - Contestar
reference of speakers of Oontz Angle 3 ULTRA U12A pls to replacement speaker
Luis Calderon - Contestar
any luck on replacement speakers?
Tirso Ramirez - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 28
Todo El Tiempo: 1,102
